[petsc-dev] disable 'info' debug messages with PetscInfoAllow
Tue Jun 16 07:20:49 CDT 2015
On Tue, Jun 9, 2015 at 4:15 PM, Thomas Hisch <t.hisch at gmail.com> wrote:
> Hello,
> i want to conditionally enable and disable the 'info' log level in a
> python script using PetscInfoAllow. Is this possible in principle? I have
> tried to write the missing wrapper for PetscInfoAllow in petsc4py (see
> https://bitbucket.org/petsc/petsc4py/issue/25). However, disabling the
> 'info' log level with PetscInfoAllow(PETSC_FALSE, NULL) has no effect.
> after it was enabled with PetscInfoAllow(PETSC_TRUE, NULL).
Hmm, it really looks to me like this should work and I believe it does in
C. Do you have a small test?
    Matt
> Best regards,
> Thomas
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150616/a7bb7bc7/attachment.html>
