[petsc-dev] PETSc release based on master before 9 pm tonight
Tue Jun 9 10:32:49 CDT 2015
On Tue, 9 Jun 2015, Eric Chamberland wrote:
> On 06/08/2015 04:54 PM, Satish Balay wrote:
> > Please do check src/docs/website/documentation/changes/dev.html and
> > update it with any missing changes entries..
> > http://www.mcs.anl.gov/petsc/documentation/changes/dev.html
> > thanks,
> > Satish
> > On Mon, 8 Jun 2015, Barry Smith wrote:
> > >    If the nightly tests run (which they now should) Satish will be making
> > >    the release maint branch and tarball Tuesday morning at 9am. Please do
> > >    not make any additional changes to master until then unless you
> > >    absolutely know the fixes are needed and don't break anything.
> > >     Barry
> Maybe support for Cholesky with MKL_PARDISO should be mentioned?
>  (ref:
> https://bitbucket.org/petsc/petsc/pull-request/311/modification-for-sbaij-support-with-mkl/diff)
Added now.
thanks,
Satish
