[petsc-dev] Titan error
Thu Jun 4 21:53:53 CDT 2015
  Hmm,
You do not have write permissions to the --prefix directory /autofs/na3_home1/adams/petsc_master_opt64idx_pgi
                          You will be prompted for the sudo password for any external package installs
Do you have write permission for this directory?
To test if you have write permission it does the following code:
def setInstallDir(self):
    ''' setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH'''
    self.installSudo        = ''
    self.installSudoMessage = ''
    if self.framework.argDB['prefix']:
      self.dir = self.framework.argDB['prefix']
      try:
        os.makedirs(os.path.join(self.dir,'PETScTestDirectory'))
        os.rmdir(os.path.join(self.dir,'PETScTestDirectory'))
      except:
        self.installSudoMessage = 'You do not have write permissions to the --prefix directory '+self.dir+'\nYou will be prompted for the sudo password for any external package installs'
Can you make a directory in /autofs/na3_home1/adams/ ?
  Barry
> On Jun 4, 2015, at 9:43 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Yet again, this one does have a slightly amusing and slightly baffling error message though.
> Mark
> <configure.log>
