[petsc-dev] Adding support memkind allocators in PETSc
Jed Brown jed at jedbrown.org
Wed Jun 3 21:28:11 CDT 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
>   Richard has access to the hardware
Is this true?  Or he will have hardware "soon"?
>   and is not going to "lie to us" that "oh it helps so much" because
>   he knows that you will test it yourself and see that he is lying.
I'm not at all worried about him lying, but I'm concerned about being
able to sample across a sufficiently broad range of apps/configurations.
Maybe he can run some PETSc examples and PFLOTRAN, which is a good
start, but may not be running in the appropriately memory-constrained
circumstances of a package with particles like pTatin, for example.  We
care not just about the highs but also about the confusing corners that
users will undoubtedly encounter.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150603/d95e514f/attachment.sig>
