[petsc-dev] Adding support memkind allocators in PETSc
Jed Brown jed at jedbrown.org
Wed Jun 3 20:54:24 CDT 2015
Richard Mills <rtm at utk.edu> writes:
> On Wed, Jun 3, 2015 at 6:04 PM, Jed Brown <jed at jedbrown.org> wrote:
>> Have you heard anything back about whether move_pages() will work?
> move_pages() will work to move pages between MCDRAM and DRAM right
> now,
Great!
> but it screws up memkind's partitioning of the heap (it won't be aware
> that the pages have been moved).
Then memkind is stupid or the kernel isn't exposing the correct
information to memkind.  Tell them to not be lazy and do it right.
> Jed, I'm with you in thinking that, ultimately, there actually needs to be
> a way to make these kinds of decisions based on global information.  We
> don't have that right now.  But if we get some smart allocator (and
> migrator) that gives us, say malloc_use_oracle() to always make the good
> decision,
The oracle has to see into the future.  move_pages() is so much more
powerful.
> we still should have something like a PetscAdvMalloc() that provides a
> context to allow us to pass advice to this smart allocator to provide
> hints about how it will be accessed, whatever.
What does the caller know?  What good is the context if we always pass
I_HAVE_NO_IDEA?
> In a lot of cases, simple size-based allocation is probably the way to go.
> An option to do automatic size-based placement is even in the latest
> memkind sources on github now, but it will do that for the entire
> application.
That's crude; I'd rather have each library use its own threshold.
> I'd like to be able to restrict this to only the PETSc portion: Maybe
> a code that uses PETSc also needs to allocate some enormous lookup
> tables that are big but have accesses that are really latency- rather
> than bandwidth-sensitive.  Or, to be specific to a code I actually
> know, I believe that in PFLOTRAN there are some pretty large
> allocations required for auxiliary variables that don't need to go in
> high-bandwidth memory, though we will want all of the large PETSc
> objects to go in there.
Fine.  That involves a couple lines of code.  Go into PetscMallocAlign
and add the ability to use memkind.  Add a run-time option to control
the threshold.  Done.
If you want complexity to bleed into the library (and necessarily into
user code if given any power at all), I think you need to demonstrate a
tangible benefit that cannot be obtained by something simpler.  Consider
the simple and dumb threshold above to be the null hypothesis.
This is just my opinion.  Feel free to make a branch with whatever you
prefer.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150603/08670774/attachment.sig>
