[petsc-dev] memory leak
Mon Jun 1 13:05:53 CDT 2015
An additional note: One has to remember the following about git - to
avoid potential misinterpretation of the status flag.
origin/branchname is a local representation of 'branchname' that is
present in the remoterepo. But its not a direct reference to
remoterepo/branchname.
i.e in '/home/balay/petsc (master=)' - the '=' flag says: the local
master branch is in sync with local origin/master - but not
necessarily in sync with remoterepo/master.
However 'git fetch' comand syncs all such local origin/branchnames
[with the latest commits in remoterepo/branchnames]
So - one can do a 'git fetch' - and then look at the status flag
'=,>,<' and try to infer if 'remoterepo/master' (via origin/master)
and 'master' are in same state - or not.
Satish
On Mon, 1 Jun 2015, Satish Balay wrote:
> On Mon, 1 Jun 2015, Mark Adams wrote:
> I use:
> export GIT_PS1_SHOWDIRTYSTATE=1
> export GIT_PS1_SHOWUPSTREAM="auto"
> export PS1='\[\e[32m\]\u@\h \[\e[36m\]${PWD}\[\e[1m\]\[\e[35m\]$(__git_ps1 " (%s)")\[\e[0m\]\n\$ '
> And I see something like the following in addition to the branch name.
> balay at asterix /home/balay/petsc (master=)
> Here - the status flag currently is '='. The usual values are:
> '=' => both branches origin/master, master are in sync
> '<' => there are new remote changes that I should pull
> '>' => there are localchages that I should push.
> And there are other status flags that get displayed based on local
> edits, stuff added to index etc..
> For eg:
> $ echo 'x' >> makefile
> balay at asterix /home/balay/petsc (master *=)
> $ git add makefile
> balay at asterix /home/balay/petsc (master +=)
> $ git commit -m 'test commit'
> [master 7672695] test commit
>  1 file changed, 1 insertion(+)
> balay at asterix /home/balay/petsc (master>)
> $ git reset --hard origin/master
> HEAD is now at e06cc25 Custom Fortran stub pcfieldsplitgetsubksp_() did not free array containing the KSPs
> So one can potentially keep track of how the changes on the branch are
> evolving - and not be *suprised* by the final state you are at. [which
> can be checked with 'git log origin/master..master' command].
> One can always reset the branch - pickup relavent stuff from abandoned
> branches etc.
> Satish
