[petsc-dev] problem when creating a new ksp that calls another one
Wed Jul 15 14:13:05 CDT 2015
On Wed, Jul 15, 2015 at 12:04 PM, Raphaël Couturier <
raphael.couturier at univ-fcomte.fr> wrote:
> Hello,
> I want to make a new solver inside petsc.
> This solver is based on a 2 stage method. So I have one outer iteration
> and one inner iteration. For the inner iteration I can use gmres or one of
> its variants.
> I succeeded to make my algorithm by creating a new ksp (that copies the
> linear system). So I have tried to do that without creating a new ksp. It
> works well with ksp examples that don't use dmda and with snes examples.
The code you sent does not make any sense to me. How can KSPSolve(ksp,
NULL, NULL) be meaningful?
Also, can't you get exactly this effect using PCKSP?
    Matt
> So I have tried to make a really simple ksp (only to test) in which I
> simply call another ksp.
> Here is the part of the code (and attached is the complete code):
>    PetscErrorCode ierr;
>    ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>    KSPSetType(ksp,KSPFGMRES);
>    ierr = KSPSolve(ksp, NULL, NULL); CHKERRQ(ierr);
>    PetscFunctionReturn(0);
> For example with the ksp example 15:
>  time $PETSC_DIR/arch-linux2-c-debug/bin/mpirun  -np 3    ./ex15 -m 200 -n
> 200 -ksp_type test  -ksp_rtol 1e-10 -pc_type mg -ksp_monitor
> there is no problem, I obtain the good result.
> But with the ksp example 45 (based on dmda):
> time $PETSC_DIR/arch-linux2-c-debug/bin/mpirun  -np 1    ./ex45 -ksp_type
> It crashes with that (I didn't change anything in ex45)
> [0]PETSC ERROR: Object is in wrong state
> [0]PETSC ERROR:  Vec is locked read only, argument # 1
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
> for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.6.0, Jun, 09, 2015
> [0]PETSC ERROR: ./ex45 on a arch-linux2-c-debug named extinction by
> couturie Wed Jul 15 18:45:39 2015
> [0]PETSC ERROR: Configure options --download-openmpi --download-hypre
> --download-f2cblaslapack --with-fc=0
> [0]PETSC ERROR: #1 VecGetArray() line 1646 in
> /home/couturie/work/petsc-3.6.0/src/vec/vec/interface/rvector.c
> [0]PETSC ERROR: #2 VecGetArray3d() line 2411 in
> [0]PETSC ERROR: #3 DMDAVecGetArray() line 77 in
> /home/couturie/work/petsc-3.6.0/src/dm/impls/da/dagetarray.c
> [0]PETSC ERROR: #4 ComputeRHS() line 84 in
> /home/couturie/work/petsc-3.6.0/src/ksp/ksp/examples/tutorials/ex45.c
> [0]PETSC ERROR: #5 KSPSetUp() line 277 in
> /home/couturie/work/petsc-3.6.0/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: #6 KSPSolve() line 546 in
> [0]PETSC ERROR: #7 KSPSolve_TEST() line 43 in
> /home/couturie/work/petsc-3.6.0/src/ksp/ksp/impls/gmres/test.c
> [0]PETSC ERROR: #8 KSPSolve() line 604 in
> [0]PETSC ERROR: #9 main() line 51 in
> I don't understand since many examples in snes are good with my code and
> they use dmda.
> Do any of you have an idea of the problem?
> Of course, I have a bad solution that consists in creating a new ksp but I
> would like to do without, if possible.
> Thank you in advance,
> Regards,
> Raphaël Couturier
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150715/4d335223/attachment.html>
