[petsc-dev] Julia Petsc Wrapper
Jared Crean jcrean01 at gmail.com
Tue Jul 14 21:35:08 CDT 2015
     Hello,
         PETSC_SCALAR is not a symbol either.  I skimmed through the
names in the shared library, and it doesn't look like any data type
information is there.
         Jared Crean
On 7/14/2015 9:22 PM, Matthew Knepley wrote:
> On Tue, Jul 14, 2015 at 8:03 PM, Jared Crean <jcrean01 at gmail.com
> <mailto:jcrean01 at gmail.com>> wrote:
>         Hello,
>             PETSC_USE_COMPLEX isn't a symbol in the shared library
>     when Petsc is built with complex scalars, so I don't see a way to
>     access it at runtime. I'll have to write a simple C program that
>     uses sizeof() and write the value to a file.
> That is crazy. How about
>   isComplex = PETSC_COMPLEX == PETSC_SCALAR
>    Matt
>             As for the MPI communicator, the julia MPI package uses a
>     C int to store it, so I will typealias to that to ensure
>     consistency.  If an MPI implementation uses an 8 byte pointer,
>     MPI.jl will have to change too.
>         Jared Crean
>     On 7/14/2015 1:04 PM, Matthew Knepley wrote:
>>     On Tue, Jul 14, 2015 at 10:56 AM, Jared Crean <jcrean01 at gmail.com
>>             Hello everyone,
>>                 I got the package in a reasonably working state and
>>         Travis testing setup, so I am putting the package up on Github.
>>         https://github.com/JaredCrean2/PETSc.jl
>>                 There is still a lot more work to do, but its a start.
>>                 A couple questions:
>>                 When looking though the code, I noticed the MPI
>>         communicator is being passed as a 64 bit integer. mpi.h
>>         typedefs it as an int, so shouldn't it be a 32 bit integer?
>>     Some MPI implementations store the communicator as a pointer,
>>     which may be 64 bits. I think the only thing the standard says is
>>     that MPI_Comm should be defined.
>>                 Also, is there a way to find out at runtime what
>>         datatype a PetscScalar is?  It appears PetscDataTypeGetSize
>>         does not accept PetscScalar as an argument.
>>     If PETSC_USE_COMPLEX is defined its PETSC_COMPLEX, otherwise its
>>     PETSC_REAL. You can also just use sizeof(PetscScalar). What do you
>>     want to do?
>>       Thanks,
>>          Matt
>>             Jared Crean
>>         On 07/06/2015 09:02 AM, Matthew Knepley wrote:
>>>         On Mon, Jul 6, 2015 at 4:59 AM, Patrick Sanan
>>>         <patrick.sanan at gmail.com <mailto:patrick.sanan at gmail.com>>
>>>         wrote:
>>>             I had a couple of brief discussions about this at
>>>             Juliacon as well. I think it would be useful, but there
>>>             are a couple of things to think about from the start of
>>>             any new attempt to do this:
>>>             1. As Jack pointed out, one issue is that the PETSc
>>>             library must be compiled for a particular precision.
>>>             This raises some questions - should several versions of
>>>             the library be built to allow for flexibility?
>>>             2. An issue with wrapping PETSc is always that the
>>>             flexibility of using the PETSc options paradigm is
>>>             reduced - how can this be addressed? Could/should an
>>>             expert user be able to access the options database
>>>             directly, or would this be too much violence to the
>>>             wrapper abstraction?
>>>         I have never understood why this is an issue. Can't you just
>>>         wrap our interface level, and use the options just as we do?
>>>         That
>>>         is essentially what petsc4py does. What is limiting in this
>>>         methodology? On the other hand, requiring specific types,
>>>         ala FEniCS,
>>>         is very limiting.
>>>            Matt
>>>             On Sat, Jul 4, 2015 at 11:00 PM, Jared Crean
>>>             <jcrean01 at gmail.com <mailto:jcrean01 at gmail.com>> wrote:
>>>                 Hello,
>>>                      I am a graduate student working on a CFD code
>>>                 written in Julia, and I am interested in using Petsc
>>>                 as a linear solver (and possibly for the non-linear
>>>                 solves as well) for the code.  I discovered the
>>>                 Julia wrapper file Petsc.jl in Petsc and have
>>>                 updated it to work with the current version of Julia
>>>                 and the MPI.jl package, using only MPI for
>>>                 communication (I don't think Julia's internal
>>>                 parallelism will scale well enough, at least not in
>>>                 the near future).
>>>                      I read the discussion on Github
>>>                 [https://github.com/JuliaLang/julia/issues/2645],
>>>                 and it looks like
>>>                 there currently is not a complete package to access
>>>                 Petsc from Julia. With your permission, I would like
>>>                 to use the Petsc.jl file as the basis for developing
>>>                 a package.  My plan is create a lower level
>>>                 interface that exactly wraps Petsc functions, and
>>>                 then construct a higher level interface, probably an
>>>                 object that is a subtype of Julia's AbstractArray,
>>>                 that allows users to store values into Petsc vectors
>>>                 and matrices.  I am less interested in integrating
>>>                 tightly with Julia's existing linear algebra
>>>                 capabilities than ensuring good scalability. The
>>>                 purpose of the high level interface it simple to
>>>                 populate the vector or matrix.
>>>                      What do you think, both about using the
>>>                 Petsc.jl file and the  overall approach?
>>>                      Jared Crean
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         results to which their experiments lead.
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150714/e28d6bcc/attachment.html>
