[petsc-dev] PETSc and threads
Mon Jan 19 19:03:34 CST 2015
On Mon, Jan 19, 2015 at 6:53 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Jan 19, 2015, at 5:23 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Barry Smith <bsmith at mcs.anl.gov> writes:
> >>   Whose legacy applications? Presumably all PETSc legacy applications
> >>   which are written for pure MPI are either MPI scalable or have
> >>   flaws in the non-PETSc part that make them non-MPI scalable but
> >>   presumably that could be fixed?
> > Or they have already bought into threads for other reasons.  People
> > rarely design applications based on unbiased data.
>    Not that many and mostly half-assed I would say. In most cases I
> believe they can just turn off the use of threads in their code and be
> fine. That is few of them are using threads due to "large amounts of data
> that can not be parallelized" but most are doing it just because they were
> told to use threads. I don't buy the legacy argument except for a tiny
> number of apps we can safely ignore, or hack if need be by using shared
> memory and turning off some of the MPI processes during the users
> "threaded" portions of the code.
> >>   Are you talking about applications with for example redundant
> >>   storage of mesh info, hence it is not MPI scalable? Well it is not
> >>   going to be MPI + thread scalable either (though the threads will
> >>   help for a while as you said).
> > Correct, but if the number of nodes is not increasing, they'll be able
> > to live with certain types of non-scalability for a while, especially if
> > their goal is science/engineering output rather than "scalability" on
> > DOE's computers.
> >>   And as you noted before even the redundant mesh info business can
> >>   be handled with the MPI window stuff just as well if not better
> >>   than threads anyways. Be more specific with what legacy
> >>   applications and what features of those apps.
> > Apps that already committed to threads.  And it doesn't have to be
> > better even in their own tests.  I recently reviewed a paper written by
> > an esteemed colleague that is promoting a "new" threading model that
> > performs uniformly worse than the naive MPI implementation they have had
> > for years.  And it was presented as a positive result because "MPI won't
> > scale", despite the new thing showing worse performance and worse
> > scalability on every numerical example in the paper.
>    I hope you recommended rejecting the paper, it should be rejected. This
> kind of crap just makes our life harder.
> > If we take the hard-line approach that PETSc will not support threads in
> > any form, we're going to be swimming upstream for a sizable class of
> > apps and libraries.  I think we should encourage people to choose
> > processes, but for those that buy into threads for whatever reason,
> > logical or not, we would be a better library if we can offer them good
> > performance.
>     There is a cost to PETSc in terms of "lost cool new functionality" and
> improved solvers and improved code by us devoting/wasting intellectual and
> time energy to "mucking with threads" to make them reasonable. Is that cost
> worth the effort? I doubt it. I'd much rather have you working on other
> stuff then make work.
>    On the other hand there is the political cost in refusing to do what
> the sheeple tell us to do. So why don't we just say we're doing thread
> stuff but not bother. Or if that won't work just drop the damn openMP
> pragmas into the code (strip out the threadcomm stuff) and call it a day?
> That requires little intellectual energy or time compared to "doing threads
> right" but satisfies your criteria.
I guess I am for this. It is very close to what we did for GPUs, and that
seems like it was the right level of effort. It could
be that eventually what Karl is doing really pays off for future machines,
but we have taken the pressure off by doing something
easy and obvious that allows us to point to it every time a know-nothing
says "GPU!".
> > Also note that if the vendors stick with their silly high-latency
> > node-wide coherence, a larger fraction of users would be able to run
> > their science of interest on a single node, in which case we could
> > provide practical parallel solvers to applications that are not
> > interested in dealing with MPI's idiosyncrasies.
>    Maybe if we improved our API to hide more of "MPI's idiosyncrasies"
> such as revisiting our "FormFunctionLocal" to make it friendly and even
> going as far as to have a simplified MPI_Comm less API (that assumes
> MPI_COMM_WORLD or a fixed subset) for everything? If we did this then the
> user (without even knowing) would actually be writing an application that
> was not restricted to one node and yet they would have the "simplicity" of
> no MPI in their application or parallelism in their model.
I think this is worth more effort. We have had the kernel discussion more
than once, but I am for thinking hard about
kernel interface/memory layout for these routines. Composability here is
non-existent, so we can keep turning the crank :)
>    As far as I am concerned if you measure the total memory bandwidth of
> the system, then based on that predict the 'solver' performance and get
> some reasonable percentage (> 80?) of the predicted that scales, then you
> are done. You don't need to justify using MPI instead of threads (or any
> model versus any other model) because switching the model (at what ever
> cost) will only give you an additional 100/80 = 1.25 hence 25 percent
> improvement assuming the alternative model is perfect, which is won't be.
> The problem with people pushing the thread model is that they "think" that
> it magically solves the memory bandwidth problem when it doesn't help that
> all. So when people question us why can't we just answer by asking them how
> threads improves the accessible memory bandwidth?
Can we hire someone to inject this into an ASCR PM Inception-like?
   Matt
>    You are the one who believes the pure MPI model is the best technically
> now and into the future, you don't need to compromise so easily.
>    Barry
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150119/265938b1/attachment.html>
