[petsc-dev] prefix install and module file
Thu Jan 15 10:15:48 CST 2015
On Thu, 15 Jan 2015, Lisandro Dalcin wrote:
> On 15 January 2015 at 16:13, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >> On Jan 15, 2015, at 4:56 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> >> On 15 January 2015 at 12:16, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> >> Barry, BTW, would you mind moving lib/petsc-conf/install.py to config/
> >> ? IMHO, it is a more appropriate place for the install script.
> >     Go ahead and make this change in the commit you make to update setup.py
> BTW, is there any good reason to install "configure.log.bkp" ?
> Otherwise, I'll explicitly exclude this file from install.py
configure.log.bkp is more for keeping track of "previous build" - so
it can be excluded from 'install'.
[previously we would concatenate all previous failed build info into
the same configure.log]
Satish
