[petsc-dev] prefix install and module file
Aron Ahmadia aron at ahmadia.net
Thu Jan 15 10:07:45 CST 2015
That all sounds reasonable to me.
On Thu, Jan 15, 2015 at 11:06 AM, Lisandro Dalcin <dalcinl at gmail.com> wrote:
> On 15 January 2015 at 16:39, Aron Ahmadia <aron at ahmadia.net> wrote:
> > The only thing I would suggest is making it clear from invoking setup.py
> > that it does not offer an explicit build stage.
> I could start the script with
> if "setuptools" not in sys.modules:
>    # tell user to not run setup.py by hand
> but let's handle that later, first I want to get it working.
> >  I'm guessing you are going
> > to not even use distutils.
> Well, I'll keep using some setuptools/distutils stuff to make setup.py
> working.
> >  Doesn't pip run some other command to get the
> > list of dependencies?
> yes, it runs egg_info
> Lisandro Dalcin
> Research Scientist
> Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> Numerical Porous Media Center (NumPor)
> King Abdullah University of Science and Technology (KAUST)
> http://numpor.kaust.edu.sa/
> 4700 King Abdullah University of Science and Technology
> al-Khawarizmi Bldg (Bldg 1), Office # 4332
> Thuwal 23955-6900, Kingdom of Saudi Arabia
> http://www.kaust.edu.sa
> Office Phone: +966 12 808-0459
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150115/72e9c549/attachment.html>
