[petsc-dev] prefix install and module file
Aron Ahmadia aron at ahmadia.net
Thu Jan 15 07:39:57 CST 2015
The only thing I would suggest is making it clear from invoking setup.py
that it does not offer an explicit build stage. I'm guessing you are going
to not even use distutils. Doesn't pip run some other command to get the
list of dependencies?
On Thursday, January 15, 2015, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Jan 15, 2015, at 4:56 AM, Lisandro Dalcin <dalcinl at gmail.com
> <javascript:;>> wrote:
> > On 15 January 2015 at 12:16, Lisandro Dalcin <dalcinl at gmail.com
> > Barry, BTW, would you mind moving lib/petsc-conf/install.py to config/
> > ? IMHO, it is a more appropriate place for the install script.
>     Go ahead and make this change in the commit you make to update setup.py
>    Barry
> > Lisandro Dalcin
> > Research Scientist
> > Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
> > Numerical Porous Media Center (NumPor)
> > King Abdullah University of Science and Technology (KAUST)
> > http://numpor.kaust.edu.sa/
> > 4700 King Abdullah University of Science and Technology
> > al-Khawarizmi Bldg (Bldg 1), Office # 4332
> > Thuwal 23955-6900, Kingdom of Saudi Arabia
> > http://www.kaust.edu.sa
> > Office Phone: +966 12 808-0459
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150115/b201696d/attachment.html>
