[petsc-dev] configure tetgen error
Tue Jan 13 21:14:41 CST 2015
  I made those changes. Did I forget to push them and then deleted the directory?
  Barry
> On Jan 13, 2015, at 9:12 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> looks like ctetgen requires the following change [to be in sync with
> 'conf' -> 'petsc-conf' change on the petsc makefile side]
> Satish
> balay at asterix /home/balay/git-repo/ctetgen (master *=)
> $ git diff |cat
> diff --git a/makefile b/makefile
> index 7e97840..f4d6a20 100644
> --- a/makefile
> +++ b/makefile
> @@ -10,13 +10,13 @@ DIRS     =
> MANSEC   =
> LOCDIR   =
> -include ${PETSC_DIR}/conf/variables
> +include ${PETSC_DIR}/lib/petsc-conf/variables
> LIBBASE    = libctetgen
> LIBNAME    = ${LIBBASE}.${AR_LIB_SUFFIX}
> CLEANFILES = ${LIBNAME}
> -include ${PETSC_DIR}/conf/rules
> +include ${PETSC_DIR}/lib/petsc-conf/rules
> install-ctetgen:
>        ${MKDIR} ${DESTDIR}/include
> On Tue, 13 Jan 2015, Adrian Croucher wrote:
>> hi
>> Just pulled next branch and tried to reconfigure, but it chokes when trying to
>> compile tetgen (I use the --download-ctetgen option):
>> Error running make on Ctetgen: Could not execute "cd
>> /home/acro018/software/PETSc/code/linux-gnu-c-opt/externalpackages/ctetgen &&
>> /usr/bin/make PET
>> SC_DIR=/home/acro018/software/PETSc/code clean lib":
>> makefile:13: /home/acro018/software/PETSc/code/conf/variables: No such file or
>> directory
>> makefile:19: /home/acro018/software/PETSc/code/conf/rules: No such file or
>> directory
>> make: *** No rule to make target
>> `/home/acro018/software/PETSc/code/conf/rules'.  Stop.
>> Is this a casualty of recent changes to paths- or have I messed something up?
>> Cheers, Adrian
