[petsc-dev] configure tetgen error
Tue Jan 13 21:07:24 CST 2015
   Hmm, should be working again. Try removing linux-gnu-c-opt and run again (--download-xxxx) caches its values there so maybe it got something outdated. If problem persists send configure.log
   Barry
> On Jan 13, 2015, at 8:39 PM, Adrian Croucher <a.croucher at auckland.ac.nz> wrote:
> hi
> Just pulled next branch and tried to reconfigure, but it chokes when trying to compile tetgen (I use the --download-ctetgen option):
> Error running make on Ctetgen: Could not execute "cd /home/acro018/software/PETSc/code/linux-gnu-c-opt/externalpackages/ctetgen && /usr/bin/make PET
> SC_DIR=/home/acro018/software/PETSc/code clean lib":
> makefile:13: /home/acro018/software/PETSc/code/conf/variables: No such file or directory
> makefile:19: /home/acro018/software/PETSc/code/conf/rules: No such file or directory
> make: *** No rule to make target `/home/acro018/software/PETSc/code/conf/rules'.  Stop.
> Is this a casualty of recent changes to paths- or have I messed something up?
> Cheers, Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 84611
