[petsc-dev] PETSc and threads
Fri Jan 9 21:11:30 CST 2015
> On Jan 9, 2015, at 8:21 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>     Just say: "I support the pure MPI model on multicore systems
>>     including KNL" if that is the case or say what you do support;
> I support that (with neighborhood collectives and perhaps
> MPI_Win_allocate_shared) if they provide a decent MPI implementation.
   Damn it, you still cannot just make a statement without putting in caveats!
   Back to the question of how we respond to Intel's queries. Could the text basically start as
   Our plan to improve PETSc SOLVERS performance for KNL systems is to provide an implementation of VecScatter, PetscSF, VecAssembly communication and MatAssembly communication using MPI 3 neighborhood collectives. This will also provide improvement of PETSc performance on Intel HSW systems. Thus PETSc application codes and frameworks such as MOOSE would portably port over to the KNL systems without major or even minor rewrites by the application developers.
  The use of MPI 3 neighborhood collectives will allow PETSc to take advantage of the local memories available in the KNL and will avoid all the large overhead of OpenMP parallel region launches .... blah blah blah with specific data about Intel not doing better than MPI only and timings for OpenMP regions.....
   Make sense? Or do I still not understand what you are saying?
  Barry
Say they don't do the neighborhood collectives and perhaps MPI_Win_allocate_shared properly; in fact they don't do it at all or they just have terrible performance. What about using the "light weight" MPI model of the RPI guys? Have a single MPI process per node but spawn all the threads at the beginning and have each of these threads run like "light weight" MPI processes from the user perspective able to make (a subset of) MPI calls (So PETSc code and application code would look pretty much the same as today except we add use of neighborhood collectives in VecScatter() and PetscSF etc)? Could the RPI guys code be a starting point for this, or would it just be too damn hard  for an outside group to do it properly on KNL? (Essentially this means writing ourselves (with others) the parts of MPI 3 we need to work well on such systems).
> I
> have yet to see a performance model showing why this can't perform at
> least as well as any MPI+thread combination.
> The threads might be easier for some existing applications to use.  That
> could be important enough to justify work on threading, but it doesn't
> mean we should *advocate* threading.
>>   Now what about "hardware threads" and pure MPI? Since Intel HSW
>>   seems to have 2 (or more?) hardware threads per core should there
>>   be 2 MPI process per core to utilize them both? Should the "extra"
>>   hardware threads be ignored by us? (Maybe MPI implementation can
>>   utilize them)? Or should we use two threads per MPI process (and
>>   one MPI process per core) to utilize them? Or something else?
> Hard to say.  Even for embarrassingly parallel operations, using
> multiple threads per core is not a slam dunk because you slice up all
> your caches.  The main benefit of hardware threads is that you get more
> registers and can cover more latency from poor prefetch.  Sharing cache
> between coordinated hardware threads is exotic and special-purpose, but
> a good last-step optimization.  Can it be done nearly as well with
> MPI_Win_allocate_shared?  Maybe; that has not been tested.
>>   Back when we were actively developing the PETSc thread stuff you
>>   supported using threads because with large domains
> Doesn't matter with large domains unless you are coordinating threads to
> share L1 cache.
>>   due to fewer MPI processes there are (potentially) a lot less ghost
>>   points needed.
> Surface-to-volume ratio is big for small subdomains.  If you already
> share caches with another process/thread, it's lower overhead to access
> it directly instead of copying out into separate blocks with ghosts.
> This is the argument for using threads or MPI_Win_allocate_shared
> between hardware threads sharing L1.  But if you don't stay coordinated,
> you're actually worse off because your working set is non-contiguous and
> doesn't line up with cache lines.  This will lead to erratic performance
> as problem size/configuration is changed.
> To my knowledge, the vendors have not provided super low-overhead
> primitives for synchronizing between hardware threads that share a core.
> So for example, you still need memory fences to prevent reordering
> stores to occur after loads.  But memory fences are expensive as the
> number of cores on the system goes up.  John Gunnels coordinates threads
> in BQG-HPL using cooperative prefetch.  That is basically a side-channel
> technique that is non-portable and if everything doesn't match up
> perfectly, you silently get bad performance.
> Once again, shared-nothing looks like a good default.
