[petsc-dev] Saving monitor information
Tue Jan 6 12:10:00 CST 2015
Should we have a mechanism to save and restore monitor information, so that
monitors
can be dynamically set when solvers are associated with other objects?
For example, you could associate a monitor with a DM, and then if you call
  SolverSetDM()
the monitors would be set into the solver. They would also have to be
removed
if SetDM() was called again.
Is this desirable?
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150106/e91a37d7/attachment.html>
