[petsc-dev] GAMG coarsening in-place
Mark Adams mfadams at lbl.gov
Fri Jan 2 13:02:11 CST 2015
On Tue, Dec 30, 2014 at 3:31 PM, Jed Brown <jed at jedbrown.org> wrote:
> I have a pretty well-conditioned problem, eigenvalues in (0.2, 1.55)
> with bjacobi/ilu.  It converges in 20-25 iterations with GMRES or with
> Chebyshev targeting this range (eigenvalues are almost uniformly
> distributed).  I'd like to make an attempt to do better using GAMG, but
> the mass term is big enough that I don't want a real coarse grid.
> Instead, I want to coarsen only once or twice "in-place" and not have
> any real coarse grid.  But it looks like GAMG is hardwired to put the
> coarsest grid on one process.  How should we add this flexibility?
Yea, time to fix this.  This comes up if you have a singular problem and
want to use an iterative coarse grid solver, or want to use a parallel LU
solver, etc.
It would be pretty easy to fix your problem by removing the hard set to one
proc if it is the last level ((PetscBool)(level==pc_gamg->Nlevels-2)), but
there are other problems that we should fix.
The only reason that I can think of that you would want to use more than
one proc on the coarse grid is if you want to use a non-default coarse grid
solver (bjacobi/lu).  Perhaps I could *not* go to one proc if the coarse
grid solver pc type is set (more below).  I don't like adding yet another
switch for this if possible.
I now see there is another problem.  I recently took out code
(mark/gamg-coarseksp) to remove setting the coarse grid KSP:
      ierr = PCSetUp_MG(pc);CHKERRQ(ierr);
      /* PCSetUp_MG seems to insists on setting this to GMRES */
      ierr = KSPSetType(mglevels[0]->smoothd, KSPPREONLY);CHKERRQ(ierr);
The problem is that GMRES is going to do a few reductions even if it has an
exact solver - this is bad on a large problem because it uses
PETSC_COMM_WORLD.
I don't know if PCSetUp_MG still sets the coarse grid solver to GMRES, but
we should fix this now as well.
One might have '-mg_coarse_pc_type lu' but have a parallel LU so just
checking this would be fragile.
Perhaps I could turn off this hard switch to one processor if
-mg_coarse_pc_type or -mg_coarse_ksp_type or
      -mg_coarse_pc_factor_mat_solver_package is set?  And also put this
KSPPREONLY back in in that case?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150102/323d0b5d/attachment.html>
