[petsc-dev] [Ideas-team] Seeking OLCF users complaining about poor build times
Mark Adams mfadams at lbl.gov
Fri Feb 27 15:22:34 CST 2015
> You might want to use 'export TMPDIR=/tmp' on all NERSC machines to
> speed this up.
Wow, I have not done a proper experiment but this configure on Edison is
15min.  Configuring has always been around 45+min. here.  And the make is
1.5 minutes.   This does not have SuperLU.
> Currently you have 'TMPDIR=/scratch1/scratchdirs/madams' [this is the
> NERSC default] - and this is slowing builds..
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150227/04cb3cfa/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150227/04cb3cfa/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150227/04cb3cfa/attachment-0001.obj>
