[petsc-dev] Seeking OLCF users complaining about poor build times
Jed Brown jed at jedbrown.org
Thu Feb 26 17:51:40 CST 2015
Victor Eijkhout <eijkhout at tacc.utexas.edu> writes:
> I think my sysadmin would frown on that. This was done on the regular
> login node which at the moment has 169 users.
How many are idle?  What is the load average?
If indeed the node is maxed out due to over-use, then I would call it a
machine provisioning issue.  My experience has been that even
under-utilized nodes are extremely slow due to file system issues.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150226/782cf9fb/attachment.sig>
