[petsc-dev] funny error on osx
Thu Feb 26 16:23:10 CST 2015
On Thu, Feb 26, 2015 at 4:20 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Humm, this did not seem to work:
Show me the actual command executed.
  Matt
> 17:15 mark/gamg-remove-eig-est
> ~/Codes/petsc/src/ksp/ksp/examples/tutorials$ make runex55
> 1,8c1,2
> <   0 KSP Residual norm 162.78
> <   1 KSP Residual norm 25.4723
> <   2 KSP Residual norm 2.96171
> <   3 KSP Residual norm 0.460234
> <   4 KSP Residual norm 0.0651141
> <   5 KSP Residual norm 0.00705928
> <   6 KSP Residual norm 0.0016868
> <   7 KSP Residual norm 0.000213352
> > [mpiexec at MacBook-Pro.local] HYDU_sock_is_local (utils/sock/sock.c:532):
> gethostbyname error on MacBook-Pro.local: Unknown host
> > [mpiexec at MacBook-Pro.local] main (ui/mpich/mpiexec.c:291): unable to
> check if localhost is local
> /Users/markadams/Codes/petsc/src/ksp/ksp/examples/tutorials
> Possible problem with ex55, diffs above
> On Thu, Feb 26, 2015 at 4:25 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> It can't run gethostbyname(), so maybe you are not connected to a network?
>> If you want to remain disconnected, use mpirun -n 2 -host
>> localhost,localhost
>> which is how I run my tests.
>>   Matt
>> On Thu, Feb 26, 2015 at 3:16 PM, Mark Adams <mfadams at lbl.gov> wrote:
>>> I started getting this error on master.  I have no threads as far as I
>>> can see.
>>> Mark
>>> 16:14 mark/gamg-remove-eig-est
>>> 1,8c1,40
>>> > Fatal error in MPI_Init_thread: Other MPI error, error stack:
>>> > MPIR_Init_thread(498)..............:
>>> > MPID_Init(177).....................: channel initialization failed
>>> > MPIDI_CH3_Init(89).................:
>>> > MPID_nem_init(320).................:
>>> > MPID_nem_tcp_init(171).............:
>>> > MPID_nem_tcp_get_business_card(418):
>>> > MPID_nem_tcp_init(377).............: gethostbyname failed,
>>> MacBook-Pro.local (errno 1)
>>> > =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>>> > =   PID 78010 RUNNING AT MacBook-Pro.local
>>> > =   EXIT CODE: 1
>>> > =   CLEANING UP REMAINING PROCESSES
>>> > =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150226/29873a27/attachment.html>
