[petsc-dev] Seeking OLCF users complaining about poor build times
Thu Feb 26 15:33:41 CST 2015
A few comments:
>      module multiprocessing found 32 cores: using make_np = 24
However - all the externalpackage builds on 'maint' are sequential.
fblaslapack
metis
parmetis
superlu_dist
hypre
[with 'master' - metis,parmetis,hypre would use parallel builds]
> Starting Configure Run at Thu Feb 26 01:01:07 2015
> Finishing Configure Run at Thu Feb 26 01:39:20 2015
so wallclock times do match..
BTW: wrt compilers - the optimization flags selected could affect
their performance. [and if they are constantly contacting the license
server - that would add up]
I'll send in numbers/logs for similar builds on mira [alcf] and my
laptop in a followup e-mail.
Satish
On Thu, 26 Feb 2015, Nathan Collier wrote:
> Barry,
> * see attached configure log
> * times are the "real time" reported by the unix time command
> * all the packages should rebuild because the reconfigure script has a
> --with-clean=1
> * not sure about the load while configuring, if you can tell me how to
> check this I can run again and monitor it
> Nate
> On Thu, Feb 26, 2015 at 3:15 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> >   Nathan,
> >    Any idea what the load was on the compiler server during the
> > configure/make ?
> >   Barry
> > > On Feb 26, 2015, at 8:13 AM, Nathan Collier <nathaniel.collier at gmail.com>
> > wrote:
> > > Ok, so I built PETSc with metis, parmetis, superlu_dist, and hyper on
> > Titan. The configure time is the second configure--when you run the
> > reconfigure script that the batch submission generates for you.
> > > configure:  38m15.488s
> > > make: 15m37.610s
> > > Nate
> > > On Thu, Feb 26, 2015 at 2:28 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > I think we made some progress in improving build times.
> > > We have some of the externalpackages building using parallel make - so
> > > that part is faster now. [ Some of this stuff might be in master - but
> > > not 3.5]
> > > Some packages are still built sequentially [for eg:
> > > fblaslapack,scalapack,superlu etc]. Fixing them can reduce build time
> > > significantly. [esp if the machine has many cores]
> > > The sequential configure [of all packages] is still the
> > > bottleneck. All compiles [by PETSc configure] are done in TMPDIR to
> > > avoid NFS I/O.
> > > Reducing the number of tests done in configure won't be easy. I have a
> > > minor fix that avoids unnecessary compiles wrt externalpackages in
> > > branch 'balay/update-configure-lib-search'
> > > BTW: I don't have access to oakridge machines..
> > > Satish
> > > On Wed, 25 Feb 2015, Barry Smith wrote:
> > > >   Shockingly this is not bad (though more than it should be), we've
> > seen times like an hour on the NERSC and ANL systems.
> > > >   If you have time :-) could you run with metis, permetis,
> > superlu_dist and hypre --with-debugging=0 and get the times separately for
> > configure and make?
> > > >   Thanks
> > > >    Barry
> > > > > On Feb 25, 2015, at 9:05 PM, Nathan Collier <
> > nathaniel.collier at gmail.com> wrote:
> > > > > I have built on Titan, I can time my configure for more accurate
> > answers but I would say it was on the order of 10-15 minutes. That is with
> > a Metis/parmetis build. Is this the type of experience you are looking for?
> > More details?
> > > > > Nate
> > > > > On Wednesday, February 25, 2015, Victor Eijkhout <
> > eijkhout at tacc.utexas.edu> wrote:
> > > > > > On Feb 25, 2015, at 1:27 PM, Barry Smith <bsmith at mcs.anl.gov>
> > wrote:
> > > > > > If you have accounts there and can reproduce slow configure/make
> > times
> > > > > Just let me know if you want a comparison to TACC machines.
> > > > > Starting with Ranger, we gave our build node its own file system
> > because I regularly crashed lustre with the petsc build. No fault of Petsc.
> > > > > And I have no complaints about the configure/make speed, on either
> > our build node or the regular user file system.
> > > > > Victor.
