[petsc-dev] funny error on osx
Mark Adams mfadams at lbl.gov
Thu Feb 26 15:16:33 CST 2015
I started getting this error on master.  I have no threads as far as I can
see.
16:14 mark/gamg-remove-eig-est
~/Codes/petsc/src/ksp/ksp/examples/tutorials$ make runex55
1,8c1,40
<   0 KSP Residual norm 162.78
<   1 KSP Residual norm 25.4723
<   2 KSP Residual norm 2.96171
<   3 KSP Residual norm 0.460234
<   4 KSP Residual norm 0.0651141
<   5 KSP Residual norm 0.00705928
<   6 KSP Residual norm 0.0016868
<   7 KSP Residual norm 0.000213352
> Fatal error in MPI_Init_thread: Other MPI error, error stack:
> MPIR_Init_thread(498)..............:
> MPID_Init(177).....................: channel initialization failed
> MPIDI_CH3_Init(89).................:
> MPID_nem_init(320).................:
> MPID_nem_tcp_init(171).............:
> MPID_nem_tcp_get_business_card(418):
> MPID_nem_tcp_init(377).............: gethostbyname failed,
MacBook-Pro.local (errno 1)
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   PID 78010 RUNNING AT MacBook-Pro.local
> =   EXIT CODE: 1
> =   CLEANING UP REMAINING PROCESSES
> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
/Users/markadams/Codes/petsc/src/ksp/ksp/examples/tutorials
Possible problem with ex55, diffs above
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150226/4305f305/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150226/4305f305/attachment.obj>
