[petsc-dev] Seeking OLCF users complaining about poor build times
Wed Feb 25 22:47:10 CST 2015
  Shockingly this is not bad (though more than it should be), we've seen times like an hour on the NERSC and ANL systems.
  If you have time :-) could you run with metis, permetis, superlu_dist and hypre --with-debugging=0 and get the times separately for configure and make?
  Thanks
   Barry
> On Feb 25, 2015, at 9:05 PM, Nathan Collier <nathaniel.collier at gmail.com> wrote:
> I have built on Titan, I can time my configure for more accurate answers but I would say it was on the order of 10-15 minutes. That is with a Metis/parmetis build. Is this the type of experience you are looking for? More details?
> Nate
> On Wednesday, February 25, 2015, Victor Eijkhout <eijkhout at tacc.utexas.edu> wrote:
> > On Feb 25, 2015, at 1:27 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > If you have accounts there and can reproduce slow configure/make times
> Just let me know if you want a comparison to TACC machines.
> Starting with Ranger, we gave our build node its own file system because I regularly crashed lustre with the petsc build. No fault of Petsc.
> And I have no complaints about the configure/make speed, on either our build node or the regular user file system.
> Victor.
