[petsc-dev] Is someone screwing with the repo?
Wed Feb 25 13:54:58 CST 2015
  I also got this message yesterday once. I deleted my local copy of the branch I was pushing, then pulled it, made my changes and then pushed it fine.
  A quick google indicates this is likely an issue with bitbucket being screwed up  https://bitbucket.org/site/master/issue/11029/remote-error-insufficient-permission-for
   What is our backup plan for when bitbucket starts to suck?
  Barry
> On Feb 25, 2015, at 8:28 AM, Matthew Knepley <knepley at gmail.com> wrote:
> knepley/feature-harmonic-advection *$:/PETSc3/petsc/petsc-dev$ git push
> git push
> Counting objects: 149, done.
> Delta compression using up to 4 threads.
> Compressing objects: 100% (35/35), done.
> Writing objects: 100% (35/35), 4.60 KiB | 0 bytes/s, done.
> Total 35 (delta 30), reused 0 (delta 0)
> remote: error: insufficient permission for adding an object to repository database objects
> remote: fatal: failed to write object
> error: unpack failed: unpack-objects abnormal exit
> To git at bitbucket.org:petsc/petsc
>  ! [remote rejected] knepley/feature-harmonic-advection -> knepley/feature-harmonic-advection (unpacker error)
> error: failed to push some refs to 'git at bitbucket.org:petsc/petsc'
>     Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
