[petsc-dev] Mark, what's the rational for keeping the Chebyshev tuning inside GAMG?
Mark Adams mfadams at lbl.gov
Wed Feb 25 09:46:49 CST 2015
On Fri, Feb 20, 2015 at 11:46 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Mark,
>    What's the rational for keeping the Chebyshev tuning inside GAMG that
> duplicates that is already support by KSPChebyshev ? I'd like to remove
> this chunk of code from GAMG since it is duplicative and instead make sure
> that the Chebyshev tuning  inside the KSPChebyshev provides everything that
> is needed.
>    Also in particular what about the /* zeroing out BC rows -- needed for
> crazy matrices */ should this be ported to KSPChebyshev ?
This is a fix for a matrix that has a norm << X, but X is put on the
diagonal for BCs.  You then get X as the eigen estimate.  We should
probably remove this ...
>     /* create cheby smoothers */
>     for (lidx = 1, level = pc_gamg->Nlevels-2; lidx <= fine_level; lidx++,
> level--) {
>       KSP       smoother;
>       PetscBool flag,flag2;
>       PC        subpc;
>       ierr = PCMGGetSmoother(pc, lidx, &smoother);CHKERRQ(ierr);
>       ierr = KSPGetPC(smoother, &subpc);CHKERRQ(ierr);
>       /* do my own cheby */
> Thanks
>    Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150225/e14100a0/attachment.html>
