[petsc-dev] Is someone screwing with the repo?
Wed Feb 25 08:28:45 CST 2015
knepley/feature-harmonic-advection *$:/PETSc3/petsc/petsc-dev$ git push
git push
Counting objects: 149, done.
Delta compression using up to 4 threads.
Compressing objects: 100% (35/35), done.
Writing objects: 100% (35/35), 4.60 KiB | 0 bytes/s, done.
Total 35 (delta 30), reused 0 (delta 0)
remote: error: insufficient permission for adding an object to repository
database objects
remote: fatal: failed to write object
error: unpack failed: unpack-objects abnormal exit
To git at bitbucket.org:petsc/petsc
 ! [remote rejected] knepley/feature-harmonic-advection ->
knepley/feature-harmonic-advection (unpacker error)
error: failed to push some refs to 'git at bitbucket.org:petsc/petsc'
    Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150225/ab55f84b/attachment.html>
