[petsc-dev] Separate operators for jacobian and preconditioner matrix on coarse MG levels
Lawrence Mitchell lawrence.mitchell at imperial.ac.uk
Tue Feb 24 12:57:31 CST 2015
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi all,
I'd like to be able to provide a matrix that is different to the
actual operator for preconditioning purposes on coarse levels.  I
think I see how to do this for PCMG, I do KSPSetComputeOperators which
migrates to the DM and will be called to setup the operators on first
KSPSolve calls.
On the other hand, for FAS, it looks like there is no way to do this:
The SNESen on each level will call SNESSetupMatrices which, if the
snes doesn't have a jacobian matrix set, will call DMCreateMatrix once
to create snes->jacobian and use that for both the jacobian and the
preconditioner for the jacobian.  Is this right, or do I have the
wrong end of the stick?
Cheers,
Lawrence
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1
iQEcBAEBAgAGBQJU7MmXAAoJECOc1kQ8PEYvgdMH/ip3m0z2g6wvURkiP680QZ63
peAKK9R1F5TJZt1OjZR9d99YcplHwsTi7EemEAJ6kaDlo1QVJ+aGTh00EcaR9yiT
lT0zlJQ8vsSa7Wwn12OGa02kZ6jh9wdRJJOhpSJoqdSih2zMhlcBYjgR1VupxpbT
ALF9TMrxi1086y7237ukbcuQh4MCidzY8t5pwglNGjGVzGMRprWGhW+0nv9Wie7f
gY6r0NAfyGc3Yi7FQvPupi07WMo1hDwnRaWVah3w11JCqVRPZXs3XxKD/KaZO/cN
0HJ70WDNJWCR1gnQ2fdFIR5grm5Dr6xIJ2rtUbBCRwldi3ZhdcmHVfjMD3o75r0=
=AB63
-----END PGP SIGNATURE-----
