[petsc-dev] PetscSSLDestroyContext
Mark Adams mfadams at lbl.gov
Tue Feb 17 10:59:07 CST 2015
I started getting this error on Edison at NERSC.  Should I configure
with --with-ssl=0​
/global/homes/m/madams/petsc_master/arch-xc30-opt64-intel/lib/libpetsc.a(send.o):
In function `PetscOpenSocket':
/global/u2/m/madams/petsc_master/src/sys/classes/viewer/impls/socket/send.c:(.text+0xc8):
warning: Using 'gethostbyname' in statically linked applications requires
at runtime the shared libraries from the glibc version used for linking
/global/homes/m/madams/petsc_master/arch-xc30-opt64-intel/lib/libpetsc.a(client.o):
In function `PetscSSLDestroyContext':
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x12):
undefined reference to `SSL_CTX_free'
In function `PetscHTTPSRequest':
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x60):
undefined reference to `SSL_write'
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x6e):
undefined reference to `SSL_get_error'
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0xcb):
undefined reference to `SSL_read'
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0xdb):
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0xef):
undefined reference to `SSL_shutdown'
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x20d):
undefined reference to `SSL_free'
In function `PetscHTTPSConnect':
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x1b8e):
undefined reference to `SSL_new'
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x1b9b):
undefined reference to `BIO_new_socket'
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x1ba9):
undefined reference to `SSL_set_bio'
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x1bb1):
undefined reference to `SSL_connect'
In function `PetscSSLInitializeContext':
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x24a1):
undefined reference to `SSLv23_method'
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x24a9):
undefined reference to `SSL_CTX_new'
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x24c0):
undefined reference to `SSL_CTX_ctrl'
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x24d0):
undefined reference to `SSL_library_init'
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x24d5):
undefined reference to `SSL_load_error_strings'
/global/u2/m/madams/petsc_master/src/sys/webclient/client.c:(.text+0x24e3):
undefined reference to `BIO_new_fp'
/usr/bin/ld: link errors found, deleting executable `xgca'
make: *** [xgca] Error 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150217/9c8a0a25/attachment.html>
