[petsc-dev] major git problem!
Mon Feb 16 21:28:29 CST 2015
Sorry about that.
I initially had a branch 'origin/balay/update-scotch_6.0.3/maint'
[orginally intended to merge to maint]
And then later - since it was suggested it wasnt' maint-worthy - I
created a branch [with my usual naming scheme]
'origin/balay/update-scotch_6.0.3'
Git rejected that - so I worked arround it by deleting
'origin/balay/update-scotch_6.0.3/maint' and creating
'origin/balay/update-scotch_6.0.3'. But I didn't realise that this
would mess up all repos [who might have the listing for
The way to fix it is:
git remote prune origin
I'll change my notation to: origin/balay/maint/feature-branch-name
I also removed 'origin/balay/update-scotch_6.0.3' - (as it is causing
grief) - and created 'origin/balay/update-scotch_6.0.3-new'.
Hopefully this will prevent grief for folks who didn't pull yet.
Satish
On Mon, 16 Feb 2015, Barry Smith wrote:
>   So removed ALL the logs and it stopped bitching
> $ rm -rf .git/logs/
> ~/Src/petsc (master<) arch-mpich
> $ git fetch
> From bitbucket.org:petsc/petsc
>  * [new branch]      balay/update-scotch_6.0.3 -> origin/balay/update-scotch_6.0.3
>   whatever the logs are
> > On Feb 16, 2015, at 5:58 PM, Jed Brown <jed at jedbrown.org> wrote:
> > Barry Smith <bsmith at mcs.anl.gov> writes:
> >> $ git pull
> >> error: There are still logs under '.git/logs/refs/remotes/origin/balay/update-scotch_6.0.3'
> >> ! [new branch]      balay/update-scotch_6.0.3 -> origin/balay/update-scotch_6.0.3  (unable to update local ref)
> >> If I delete that directory .git/logs/refs/remotes/origin/balay/update-scotch_6.0.3 I still get the error message again
> > I can't reproduce.  Can you "git fetch"?
