[petsc-dev] major git problem!
Jed Brown jed at jedbrown.org
Mon Feb 16 17:58:38 CST 2015
Barry Smith <bsmith at mcs.anl.gov> writes:
> $ git pull
> error: There are still logs under '.git/logs/refs/remotes/origin/balay/update-scotch_6.0.3'
> From bitbucket.org:petsc/petsc
>  ! [new branch]      balay/update-scotch_6.0.3 -> origin/balay/update-scotch_6.0.3  (unable to update local ref)
> If I delete that directory .git/logs/refs/remotes/origin/balay/update-scotch_6.0.3 I still get the error message again
I can't reproduce.  Can you "git fetch"?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150217/0c1131fb/attachment.sig>
