[petsc-dev] TSSolve web page
Mark Adams mfadams at lbl.gov
Fri Feb 6 12:28:54 CST 2015
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/TS/TSSolve.html#TSSolve
The TSSolve web page does not have an output parameter.  It is not clear to
my why you would use TSSetSolution.  Is there any difference between using
and not using TSSetSolution other than you do not need to give TSSolve u?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150206/faf4cbda/attachment.html>
