[petsc-dev] Valgrind defect: memory leak with PetscCommDuplicate?
Brendan Kochunas bkochuna at umich.edu
Fri Feb 6 08:52:03 CST 2015
Hi we are trying to clear valgrind defects from our code and presently
we are valgrind is reporting memory leaks like the following:
==2884==    at 0x4A07EB7: malloc (vg_replace_malloc.c:296)
==2884==    by 0x8519874: set_value.isra.0.part.1 (in
/gcc-4.6.1/toolset/openmpi-1.4.3/lib/libmpi.so.0.0.2)
==2884==    by 0x8547E4D: PMPI_Attr_put (in
==2884==    by 0x113A153: PetscCommDuplicate
==2884==    by 0x113BFA3: PetscHeaderCreate_Private
==2884==    by 0x129ADC6: MatCreate
==2884==    by 0x123C355: MatMPIAIJSetPreallocation_MPIAIJ
==2884==    by 0x124DAB4: MatMPIAIJSetPreallocation
==2884==    by 0x12549B0: MatSetUp_MPIAIJ
==2884==    by 0x1191186: MatSetUp
==2884==    by 0x10D9333: matsetup_
and...
==2884==    by 0x113A22D: PetscCommDuplicate
==2884==    by 0x10ED42B: KSPCreate
==2884==    by 0x10DA55C: kspcreate_
Is the development team aware of any memory leaks that may be coming
from PetscCommDuplicate as it may be used in the call stack shown above?
The version of PETSc we are linking with is 3.3 patch 4. And this is
built on OpenMPI v. 1.4.3.
We are trying to determine if the leak is due to
1. Our codes usage of PETSc
2. The actual PETSc library
3. PETSc's usage of MPI
3. The OpenMPI library that PETSc was built against
Any assistance in being able to point to the culprit or suggestions for
particular tests (e.g. a PETSc example) worth trying to identify the
root issue would be appreciated.
Thanks in advance!
-Brendan
