[petsc-dev] d9ca1df42eda25bc875149d6d493aad6e204c9ff
Jed Brown jed at jedbrown.org
Wed Feb 4 15:49:22 CST 2015
Mark Adams <mfadams at lbl.gov> writes:
> This commit seems to have caused my MatShell code to break:
> [22]PETSC ERROR: Object is in wrong state
> [22]PETSC ERROR:  Vec is locked read only, argument # 1
Your MatShell code is probably using VecGetArray when it should be using
VecGetArrayRead.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150204/0f5a6db5/attachment.sig>
