[petsc-dev] SuperLU build error
Garth N. Wells gnw20 at cam.ac.uk
Fri Dec 18 10:50:51 CST 2015
On 18 December 2015 at 16:45, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Garth,
>      Yes this has been an on going nuisance. Do you have this problem with
> the master development version or some previous release?
master (updated earlier today).
Garth
>    Satish,
>       I thought this was now fully resolved?
>    Barry
> > On Dec 18, 2015, at 2:52 AM, Garth N. Wells <gnw20 at cam.ac.uk> wrote:
> > I've reported before that SuperLU has a bug that causes compile failures:
> >   util.c:32:18: error: format not a string literal and no format
> arguments [-Werror=format-security]
> >        fprintf(stderr, msg);
> > I usually fix this by hand, but the way PETSc since very recently resets
> user changes in cloned external packages is overwriting the change I make.
> > There is a similar bug in SuperLU_dist that I also fix by hand.
> > Garth
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20151218/4980ff9c/attachment.html>
