[petsc-dev] PCTelescope error
Sat Dec 12 12:06:34 CST 2015
Done
> On Dec 12, 2015, at 12:59 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
> Hi Barry,
> On 12 December 2015 at 05:42, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Dave,
>    Sorry for the delay in responding; I let life get in the way of PETSc. Don't worry it won't happen again.
> No problem for the delay.
>   if (isActiveRank(psubcomm)) {
>     ierr = DMDAGetCorners(subdm,&si,&sj,NULL,&ni,&nj,NULL);CHKERRQ(ierr);
>     Ml = ni - si;
>     Nl = nj - sj;
> Note that this bug came from a misunderstanding of the meaning of ni and nj which are the widths; not the end points
> when I changed the code to
>     Ml = ni;
>     Nl = nj;
> it ran in valgrind without error.  I have pushed the fix in master and next.
> Great - thanks!
> Could you also please make the same change to the equivalent 3D function (around line 240 in the same file). It also defines the lengths of the local size as START - WIDTH.
> Thanks,
>   Dave
>   Barry
> > On Dec 8, 2015, at 7:52 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
> > Hi Barry,
> > I've encountered an issue with PCTelescope which I think is related to your changesets b2566f2, 8f5db7e which
> > introduce PetscAllreduceBarrierCheck() and MPIU_Allreduce().
> > The error message is reported below.
> > This message
> > [0]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> > appears to be produced by PetscAllreduceBarrierCheck(), but I'm not sure why it would get thrown in my use case.
> > The same telescope job run here didn't produce an error with the original pull request.
> > It seems the error does not occur when the reduction factor equals the original number of MPI ranks in comm world.
> > Stupidly I didn't add a test for that particular case, otherwise this issue would have been caught earlier.
> > Do you have ideas what the cause/fix might be?
> > Thanks,
> >   Dave
> > /Users/dmay/software/petsc-developments/petscfork/arch-gpu-debug-single/bin/mpiexec -n 4 ./ex29 -ksp_type fgmres -ksp_monitor -da_grid_x 65 -da_grid_y 65 -pc_type telescope  -ksp_view -pc_telescope_reduction_factor 2 -telescope_pc_type mg -telescope_pc_mg_levels 2 -telescope_mg_levels_pc_type jacobi -telescope_pc_mg_galerkin -telescope_mg_levels_pc_type asm
> > [2]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> > [2]PETSC ERROR: Petsc has generated inconsistent data
> > [2]PETSC ERROR: c 4160 should equal 2 * Ml 65 * Nl -1
> > [2]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > [2]PETSC ERROR: Petsc Development GIT revision: v3.4-10790-g4c50f03  GIT Date: 2015-12-04 18:13:24 -0600
> > [2]PETSC ERROR: ./ex29 on a arch-gpu-debug-single named geop-337.ethz.ch by dmay Tue Dec  8 14:18:58 2015
> > [2]PETSC ERROR: Configure options --with-fc=0 --download-mpich=yes --with-opencl --with-viennacl-include=../viennacl-dev --with-viennacl-lib= --with-debugging=yes --with-precision=single
> > [2]PETSC ERROR: #1 PCTelescopeSetUp_dmda_repart_coors2d() line 159 in /Users/dmay/software/petsc-developments/petscfork/src/ksp/pc/impls/telescope/telescope_dmda.c
> > [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> > [0]PETSC ERROR: Petsc has generated inconsistent data
> > [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > [0]PETSC ERROR: Petsc Development GIT revision: v3.4-10790-g4c50f03  GIT Date: 2015-12-04 18:13:24 -0600
> > [0]PETSC ERROR: ./ex29 on a arch-gpu-debug-single named geop-337.ethz.ch by dmay Tue Dec  8 14:18:58 2015
> > [0]PETSC ERROR: Configure options --with-fc=0 --download-mpich=yes --with-opencl --with-viennacl-include=../viennacl-dev --with-viennacl-lib= --with-debugging=yes --with-precision=single
> > [0]PETSC ERROR: #1 PetscSplitOwnership() line 84 in /Users/dmay/software/petsc-developments/petscfork/src/sys/utils/psplit.c
> > [0]PETSC ERROR: #2 PetscSplitOwnership() line 84 in /Users/dmay/software/petsc-developments/petscfork/src/sys/utils/psplit.c
> > [0]PETSC ERROR: #3 PetscLayoutSetUp() line 143 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/utils/pmap.c
> > [0]PETSC ERROR: [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> > [1]PETSC ERROR: Petsc has generated inconsistent data
> > [1]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> > [1]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > [1]PETSC ERROR: Petsc Development GIT revision: v3.4-10790-g4c50f03  GIT Date: 2015-12-04 18:13:24 -0600
> > [1]PETSC ERROR: [2]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> > [2]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> > [2]PETSC ERROR: #2 VecSetBlockSize() line 1421 in /Users/dmay/software/petsc-developments/petscfork/src/vec/vec/interface/vector.c
> > [2]PETSC ERROR: #3 VecSetBlockSize() line 1421 in /Users/dmay/software/petsc-developments/petscfork/src/vec/vec/interface/vector.c
> > [2]PETSC ERROR: #4 DMCreateGlobalVector_DA() line 42 in /Users/dmay/software/petsc-developments/petscfork/src/dm/impls/da/dadist.c
> > [2]PETSC ERROR: #5 DMCreateGlobalVector() line 764 in /Users/dmay/software/petsc-developments/petscfork/src/dm/interface/dm.c
> > [2]PETSC ERROR: #6 DMGetGlobalVector() line 163 in /Users/dmay/software/petsc-developments/petscfork/src/dm/interface/dmget.c
> > [2]PETSC ERROR: #7 PCTelescopeSetUp_dmda_permutation_2d() line 568 in /Users/dmay/software/petsc-developments/petscfork/src/ksp/pc/impls/telescope/telescope_dmda.c
> > #4 ISCreateGeneral_Private() line 568 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/is/impls/general/general.c
> > [0]PETSC ERROR: #5 ISGeneralSetIndices_General() line 683 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/is/impls/general/general.c
> > [0]PETSC ERROR: #6 ISGeneralSetIndices() line 654 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/is/impls/general/general.c
> > [0]PETSC ERROR: #7 ISCreateGeneral() line 625 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/is/impls/general/general.c
> > [0]PETSC ERROR: #8 PCTelescopeSetUp_dmda_repart_coors2d() line 163 in /Users/dmay/software/petsc-developments/petscfork/src/ksp/pc/impls/telescope/telescope_dmda.c
> > [1]PETSC ERROR: Configure options --with-fc=0 --download-mpich=yes --with-opencl --with-viennacl-include=../viennacl-dev --with-viennacl-lib= --with-debugging=yes --with-precision=single
> > [1]PETSC ERROR: #1 PetscSplitOwnership() line 84 in /Users/dmay/software/petsc-developments/petscfork/src/sys/utils/psplit.c
> > [1]PETSC ERROR: #2 PetscSplitOwnership() line 84 in /Users/dmay/software/petsc-developments/petscfork/src/sys/utils/psplit.c
> > [2]PETSC ERROR: #8 PCTelescopeSetUp_dmda() line 695 in /Users/dmay/software/petsc-developments/petscfork/src/ksp/pc/impls/telescope/telescope_dmda.c
> > [2]PETSC ERROR: #9 PCSetUp_Telescope() line 369 in /Users/dmay/software/petsc-developments/petscfork/src/ksp/pc/impls/telescope/telescope.c
> > [2]PETSC ERROR: #10 PCSetUp() line 984 in /Users/dmay/software/petsc-developments/petscfork/src/ksp/pc/interface/precon.c
> > [1]PETSC ERROR: #3 PetscLayoutSetUp() line 143 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/utils/pmap.c
> > [1]PETSC ERROR: #4 ISCreateGeneral_Private() line 568 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/is/impls/general/general.c
> > [1]PETSC ERROR: [2]PETSC ERROR: #11 KSPSetUp() line 384 in /Users/dmay/software/petsc-developments/petscfork/src/ksp/ksp/interface/itfunc.c
> > [2]PETSC ERROR: #12 main() line 77 in /Users/dmay/software/petsc-developments/petscfork/src/ksp/ksp/examples/tutorials/ex29.c
> > [2]PETSC ERROR: PETSc Option Table entries:
> > [2]PETSC ERROR: -da_grid_x 65
> > [2]PETSC ERROR: #5 ISGeneralSetIndices_General() line 683 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/is/impls/general/general.c
> > [1]PETSC ERROR: #6 ISGeneralSetIndices() line 654 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/is/impls/general/general.c
> > [1]PETSC ERROR: #7 ISCreateGeneral() line 625 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/is/impls/general/general.c
> > [1]PETSC ERROR: #8 PCTelescopeSetUp_dmda_repart_coors2d() line 163 in /Users/dmay/software/petsc-developments/petscfork/src/ksp/pc/impls/telescope/telescope_dmda.c
> > -da_grid_y 65
> > [2]PETSC ERROR: -ksp_monitor
> > [2]PETSC ERROR: -ksp_type fgmres
> > [2]PETSC ERROR: -ksp_view
> > [2]PETSC ERROR: -pc_telescope_reduction_factor 2
> > [2]PETSC ERROR: -pc_type telescope
> > [2]PETSC ERROR: -telescope_mg_levels_pc_type asm
> > [2]PETSC ERROR: -telescope_pc_mg_galerkin
> > [2]PETSC ERROR: -telescope_pc_mg_levels 2
> > [2]PETSC ERROR: -telescope_pc_type mg
> > [2]PETSC ERROR: ----------------End of Error Message -------send entire error message to petsc-maint at mcs.anl.gov----------
> > application called MPI_Abort(MPI_COMM_WORLD, 1) - process 2
> > [cli_2]: aborting job:
> > [3]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> > [3]PETSC ERROR: Petsc has generated inconsistent data
> > [3]PETSC ERROR: MPI_Allreduce() called in different locations (code lines) on different processors
> > [3]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> > [3]PETSC ERROR: Petsc Development GIT revision: v3.4-10790-g4c50f03  GIT Date: 2015-12-04 18:13:24 -0600
> > [3]PETSC ERROR: ./ex29 on a arch-gpu-debug-single named geop-337.ethz.ch by dmay Tue Dec  8 14:18:58 2015
> > [3]PETSC ERROR: Configure options --with-fc=0 --download-mpich=yes --with-opencl --with-viennacl-include=../viennacl-dev --with-viennacl-lib= --with-debugging=yes --with-precision=single
> > [3]PETSC ERROR: #1 PetscSplitOwnership() line 84 in /Users/dmay/software/petsc-developments/petscfork/src/sys/utils/psplit.c
> > [3]PETSC ERROR: #2 PetscSplitOwnership() line 84 in /Users/dmay/software/petsc-developments/petscfork/src/sys/utils/psplit.c
> > [3]PETSC ERROR: #3 PetscLayoutSetUp() line 143 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/utils/pmap.c
> > [3]PETSC ERROR: #4 ISCreateGeneral_Private() line 568 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/is/impls/general/general.c
> > [3]PETSC ERROR: #5 ISGeneralSetIndices_General() line 683 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/is/impls/general/general.c
> > [3]PETSC ERROR: #6 ISGeneralSetIndices() line 654 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/is/impls/general/general.c
> > [3]PETSC ERROR: #7 ISCreateGeneral() line 625 in /Users/dmay/software/petsc-developments/petscfork/src/vec/is/is/impls/general/general.c
> > [3]PETSC ERROR: #8 PCTelescopeSetUp_dmda_repart_coors2d() line 163 in /Users/dmay/software/petsc-developments/petscfork/src/ksp/pc/impls/telescope/telescope_dmda.c
