[petsc-dev] strangness in Chebyshev estimate of eigenvalues
Thu Aug 27 21:12:34 CDT 2015
> On Aug 27, 2015, at 5:35 PM, Jed Brown <jed at jedbrown.org> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>   This is the default behavior if one just creates a PetscRandom and uses it, so don't be going and setting seeds inside GAMG or Chebyshev.
   Yikes, you are right all three of our current random number generators have global state! What a mess. We should remove all them completely and we can complement Matt's by adding in a more modern version of Sprng that does not use global state. (Stupid Sprng fucks changed to C++)
   Barry
> You're right (my mistake), but the consequences are dangerous if the
> user is holding a PetscRandom across calls to GAMG (or anything that
> creates new PetscRandom instances).  The reason is that merely creating
> a PetscRandom reseeds the global PRNG.  (What moron thought a global
> seed was a good idea?)  Seems to me we should avoid drand48 always so we
> don't disrupt the user's source of randomness (leading to really
> confusing incorrect results).  We could use the non-disastrous
> drand48_r, but it's a GNU extension so we'd need an alternative anyway.
> If Matt changes "rander48" to the rand48_r (or erand48_r) interface,
> then we'd be okay.  This would also remove the internal variables that
> Matt forget to make static.
