[petsc-dev] Including petsc.h breaks user code
Sun Sep 14 20:36:30 CDT 2014
   Pierre,
     Thanks for reporting this, it is, indeed our bug. In petsclog.h we have macros for the various MPI calls in order to log their usage, for example,
#define MPI_Scatter(sendbuf,sendcount,sendtype,recvbuf,recvcount,recvtype,root,comm) \
 ((petsc_scatter_ct++,0) || PetscMPITypeSize(&petsc_recv_len,recvcount,recvtype) || MPI_Scatter(sendbuf,sendcount,sendtype,recvbuf,recvcount,recvtype,root,comm))
but PetscMPITypeSize() simply called MPI_Type_size() which generated an MPI error for MPI_DATATYPE_NULL
PETSC_STATIC_INLINE PetscErrorCode PetscMPITypeSize(PetscLogDouble *buff,PetscMPIInt count,MPI_Datatype type)
  PetscMPIInt mysize; return  (MPI_Type_size(type,&mysize) || ((*buff += (PetscLogDouble) (count*mysize)),0));
In the branch barry/fix-usage-with-mpidatatypenull I have added a check for this special case and avoid the MPI_Type_size() call. I will put this branch into next and if all tests pass it will be merged into maint and master and be in the next patch release.
   Thank you for reporting the problem.
   Barry
Barry still thinks MPI 1.1 is the height of HPC computing :-(
On Sep 14, 2014, at 4:16 PM, Pierre Jolivet <jolivet at ann.jussieu.fr> wrote:
> Hello,
> Could you please explain to me why the following example is not working properly when <petsc.h> (from master, with OpenMPI 1.8.1) is included ?
> $ mpicxx in-place.cpp  -I$PETSC_DIR/include -I$PETSC_DIR/$PETSC_ARCH/include -L$PETSC_DIR/$PETSC_ARCH/lib -lpetsc
> $ mpirun -np 2 ./a.out
> Done with the scatter !
> 0 0 0 0 (this line should be filled with 0)
> 1 1 1 1 (this line should be filled with 1)
> Done with the gather !
> $ mpicxx in-place.cpp  -I$PETSC_DIR/include -I$PETSC_DIR/$PETSC_ARCH/include -L$PETSC_DIR/$PETSC_ARCH/lib -lpetsc -DPETSC_BUG
> [:3367] *** An error occurred in MPI_Type_size
> [:3367] *** reported by process [4819779585,140733193388032]
> [:3367] *** on communicator MPI_COMM_WORLD
> [:3367] *** MPI_ERR_TYPE: invalid datatype
> [:3367] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
> [:3367] ***    and potentially your MPI job)
> Thank you for looking,
> Pierre
> <in-place.cpp>
