[petsc-dev] Including petsc.h breaks user code
Christophe Prud'homme christophe.prudhomme at feelpp.org
Sun Sep 14 17:56:48 CDT 2014
Hello
Pierre and I found this problem occurring using openmpi 1.8.1 petsc 3.5.1
(this was done on my side using homebrew on osx)
we haven't checked mpich. However it is disturbing that removing the
petsc.h header actually solve the problem.
from the mpi standard, if we understand correctly, we shouldn't have to
specify the data type for MPI_IN_PLACE scatter/gather operations. To avoid
either a crash with, deadlock(scatter) or wrong results (gather) with
boost::mpi we need to specify the data type.
In our code Feel++ we have added some tests to verify this behavior [1]
basically
 - mpi alone OK
 - boost::mpi alone OK (boost::mpi is just used as an alternative to
initialize mpi)
 - mpi+petsc.h  with MPI_DATATYPE_NULL in scatter crash
 - mpi+petsc.h+proper datatype OK
 - boost::mpi.h+petsc  with MPI_DATATYPE_NULL hangs in scatter
 - boost::mpi.h+petsc+proper datatype OK
 1.
https://github.com/feelpp/feelpp/blob/develop/testsuite/feelcore/test_gatherscatter.cpp
Best regards
C.
On Mon, Sep 15, 2014 at 12:37 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Sep 14, 2014 at 4:16 PM, Pierre Jolivet <jolivet at ann.jussieu.fr>
> wrote:
>> Hello,
>> Could you please explain to me why the following example is not working
>> properly when <petsc.h> (from master, with OpenMPI 1.8.1) is included ?
>> $ mpicxx in-place.cpp  -I$PETSC_DIR/include
>> -I$PETSC_DIR/$PETSC_ARCH/include -L$PETSC_DIR/$PETSC_ARCH/lib -lpetsc
>> $ mpirun -np 2 ./a.out
>> Done with the scatter !
>> 0 0 0 0 (this line should be filled with 0)
>> 1 1 1 1 (this line should be filled with 1)
>> Done with the gather !
>> -DPETSC_BUG
>> [:3367] *** An error occurred in MPI_Type_size
>> [:3367] *** reported by process [4819779585,140733193388032]
>> [:3367] *** on communicator MPI_COMM_WORLD
>> [:3367] *** MPI_ERR_TYPE: invalid datatype
>> [:3367] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now
>> abort,
>> [:3367] ***    and potentially your MPI job)
> I just built this with MPICH and it runs fine:
> master:/PETSc3/petsc/petsc-pylith$
> /PETSc3/petsc/petsc-pylith/arch-pylith-cxx-debug/bin/mpiexec -host
> localhost -n 2
> /PETSc3/petsc/petsc-pylith/arch-pylith-cxx-debug/lib/in-place-obj/in-place
> Will valgrind.
>    Matt
>> Thank you for looking,
>> Pierre
> experiments lead.
> -- Norbert Wiener
Feel++ Project Manager
Professor in Applied Mathematics
@ Université Joseph Fourier (Grenoble, France)
@ Université de Strasbourg (France)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140915/a23f7b50/attachment.html>
