[petsc-dev] bitbucket pull requests
Jed Brown jed at jedbrown.org
Sat Sep 13 18:58:05 CDT 2014
Matthew Knepley <knepley at gmail.com> writes:
> On Sat, Sep 13, 2014 at 12:23 AM, Balay, Satish <balay at mcs.anl.gov> wrote:
>>  Some additional thoughts.
>> WRT: bitbubket RFEs would be
>> 1. Config to remove merge button and suggest a copy/pasteable git fetch cmd
>> 2. Config to suggest only maint and master branches for pull requests.
>> And on our(integrator) side we create a better tractable branch name -
>> perhaps:
>> Pull#-integrator/contributor/feature (or a better encoding)
> I like these suggestions.
It would be great, but bitbucket is closed source.  You can suggest that
they change it, but can't be proactive.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140913/ff4dbaf4/attachment.sig>
