[petsc-dev] so Bitbucket and git suck once again
Patrick Sanan patrick.sanan at gmail.com
Fri Sep 12 15:36:11 CDT 2014
I cleaned things up a little in the version that is now in the main
PETSc repo (took out the fixes to VecMTDot, squashed some commits), so
that one should be used instead. Should I delete the existing PR to
avoid confusion?
On 9/12/14 5:14 AM, Barry Smith wrote:
> On Sep 11, 2014, at 8:37 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Patrick,
>      Never mind. I just need to change the git@ to access the repository. I’ll start on it tomorrow when my brain is fresh.
>    Barry
>>   Patrick,
>>     Could you please give us read access to your repository so we can fetch it?
>>    Thanks
>>      Barry
>>   git fetch git at bitbucket.org:psanan/petsc psanan/ksp-fcg:psanan/ksp-fcg
>> conq: repository does not exist.
>> fatal: Could not read from remote repository.
>> Please make sure you have the correct access rights
>> and the repository exists.
>> On Sep 11, 2014, at 7:05 PM, Jed Brown <jed at jedbrown.org> wrote:
>>> Barry Smith <bsmith at mcs.anl.gov> writes:
>>>> Jed
>>>> So, I am in my PETSc repository and want to try out Patrick Sanan’s FCG since it is cool and we ignored it too long and need to get it into the repository. He’s made a nice pull request; great. So I do
>>>> ~/Src/petsc  master $ git checkout psanan/ksp-fcg
>>>> error: pathspec 'psanan/ksp-fcg' did not match any file(s) known to git.
>>> The branch is in his repository, not ours.  Bitbucket has a major
>>> pull-request permissions problem in that he can make a PR to our
>>> repository without giving us read access to his repository.  This sounds
>>> crazy and it is.  Supposedly we would be able to merge using the web
>>> interface (if not for merge conflicts), but we can't even read the
>>> commits on the web:
>>> https://bitbucket.org/petsc/petsc/pull-request/197/kspfcg/commits
>>> If we had read access to his repository, I would run:
>>> to create a local branch in my repository named psanan/ksp-fcg.  I would
>>> then
>>> ... browse, run tests, etc
>>> git push -u origin psanan/ksp-fcg
>>> and merge if it looks good.
>>>> Then I fucking give up.
>>>> Why doesn’t bitbucket produce useful information to get his branch without being a git guru? It should show the exact magical git incantation to pull his branch.
>>>> 1) How do I pull his branch into my repository
>>>> 2) How do I know in the future when I want to do this again, how to pull his branch in when my long term memory is shot?
>>> Bitbucket is seriously dropping the ball on this interface.  GitHub
>>> email notifications include the command to pull (merging into the
>>> current branch, so not quite what we want) and have solved the
>>> permissions problem.  They also makes the PR branches available under
>>> refs/pull/*, so that you can get them without using the URL for the
>>> contributor's repo.
>>> Patrick, you have write access to the PETSc repository.  Can you just
>>> push your branches there instead of your personal repo when creating a
>>> PR?
