[petsc-dev] unwind next branch
Abhyankar, Shrirang G. abhyshr at mcs.anl.gov
Wed Sep 10 09:59:18 CDT 2014
You can delete
origin/shri/external-package-KLU
  origin/shri/feature-dm-circuit
Please keep all the other branches.
Shri
-----Original Message-----
Date: Tue, 9 Sep 2014 17:50:58 -0500
To: petsc-dev mailing list <petsc-dev at mcs.anl.gov>
Subject: [petsc-dev] unwind next branch
>Jed,
>After 3.5 release we have not unwound next branch.
>With 3.5.2 out - is it a good time to unwind?
>This might need some coordination as there are some old branches that
>are not yet merged to master/next.. (so they need rebase?)
>balay at asterix /home/balay/petsc (master)
>$ comm -12 <(git branch -r --merged next | sort) <(git branch -r
>--no-merged master | sort)
>  origin/balay/fix-glibc-2.20_DEFAULT_SOURCE
>  origin/balay/update-etags
>  origin/balay/update-hdf5
>  origin/jed/sr-driver4
>  origin/jed/vecghostgetvalues
>  origin/karpeev/fix-ksp-pcgasm
>  origin/knepley/feature-optcontrol-mg
>  origin/knepley/feature-plex-nasm
>  origin/knepley/feature-quadrature-fortran
>  origin/knepley/fix-quadrature-order
>  origin/madams/sr-driver4
>  origin/mlange05/fix-gmsh-coordinates
>  origin/next
>  origin/paulmullowney/aijcusp-ellpack-fix
>  origin/prbrune/sf-examplefix
>  origin/prbrune/snes-ex19vtkoutput
>  origin/sarich/fix-tao-linesearch-reset
>  origin/sarich/fix-tao-pounders-repeating
>  origin/sarich/tao-add-fortran-stubs
>  origin/sarich/tao-get-number-ksp-its
>  origin/sarich/tao-history-store-ksp-its
>  origin/shri/ts-dae-semi-explicit
>  origin/shri/ts-is-for-differential-variables
>  origin/shri/ts-powergrid
>  origin/stefano_zampini/pcbddc-changeofbasis
>  origin/stefano_zampini/pcbddc_deluxe
>  origin/stefano_zampini/pcbddc-primalfixes
>  origin/tisaac/dm-dim-embed-auto
>  origin/tisaac/thplex
>  origin/tisaac/thplex-remove-ksp-loop
>[how about branches that got merged from bitbucket web interface?]
>I see you [or someone else] did some branch cleanup. Perhaps there are
>more branches that can be deleted on the server.
>I see the following branches merged to v3.5 release. perhaps they can
>be deleted now?
>Thanks,
>Satish
>$ git branch -r --merged v3.5 |egrep -v origin\/\(master\|maint\|next\)
>  origin/balay/add-ISColoringValue-to-finclude
>  origin/balay/chk-optflags-in-cflags
>  origin/balay/fix-multiple-zisltogf.c
>  origin/balay/fix-win32-printf-2digit-exponent
>  origin/balay/remove_intel_fast
>  origin/barry/feature-OSX-example
>  origin/barry/feature-dmmoab-hdf5-tests
>  origin/barry/fix-istogeneral_block
>  origin/barry/fix-matlab-socket
>  origin/barry/fix-redundant-matrix
>  origin/barry/vince
>  origin/bermeo/add-mkl-pardiso
>  origin/hzhang/mat-inertia
>  origin/jed/license
>  origin/knepley/doc-fe-dualspace
>  origin/knepley/feature-problem-class
>  origin/knepley/feature-quad-fas
>  origin/knepley/fix-complex-build
>  origin/knepley/fix-fe-gpu
>  origin/sarich/fix-tao-linesearch-counter-view
>  origin/sarich/tao-purge-dm
>  origin/shri/ts-events
>  origin/stefano_zampini/pcbddc-maint
