[petsc-dev] Question about the pseudo-time stepping
Lulu Liu lulu.liu at kaust.edu.sa
Tue Sep 9 07:07:05 CDT 2014
I want to solve a stead-state problem G(u)=0 using the pseudo-transient
continuation method.
I saw the example petsc/src/ts/examples/tutorials/ex1,
  ierr = TSSetRHSJacobian(ts,J,J,*FormJacobian*,&user);CHKERRQ(ierr);
however, the analytical Jacobian in my problem is very complex and it is
not easy to give the function "*FormJacobian*". If I run the code like
 ./ex1 -ts_monitor_pseudo  -snes_mf
Is it correct? Does it involves the time derivative term when using
-snes_mf?
Thanks!
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140909/94d1c450/attachment.html>
