[petsc-dev] ccache sucks!
Sat Sep 6 22:05:14 CDT 2014
I removed "export"  - so suggesting it as:
./configure CC="ccache clang -Qunused-arguments"
or equivalent.. [for eg: CFLAGS=-Qunused-arguments]
Satish
On Sat, 6 Sep 2014, Barry Smith wrote:
>  but doesn’t ./configure bypass CC and CXX :-)
> >>  The first configure fails with ccache, removing it does not fail
> > stderr:
> > clang: warning: argument unused during compilation: '-I /var/folders/c1/ldz_dt8n2r3dtwv_chp5pfr40000gq/T/petsc-a0322M/config.setCompilers'
> > https://code.google.com/p/chromium/wiki/CCacheMac says use:
> > CXX="ccache clang++ -Qunused-arguments"
> > Satish
