[petsc-dev] PETSc with CUDA on windows with VS2013 and CUDA 6.5
Paul Mullowney paulmullowney at gmail.com
Fri Sep 5 17:51:17 CDT 2014
make all-legacy worked. I don't understand the differences, but at least
the CUDA files compile without having to manually copy and paste each
compile line.
Thanks Satish!
On Fri, Sep 5, 2014 at 1:52 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> From http://docs.nvidia.com/cuda/cuda-compiler-driver-nvcc/#axzz3CTMr1nP1
> nvcc uses the following compilers for host code compilation:
> On Linux platforms
> The GNU compiler, gcc, and arm-linux-gnueabihf-g++ for cross compilation
> to the ARMv7 architecture
> On Windows platforms
> The Microsoft Visual Studio compiler, cl
> On both platforms, the compiler found on the current execution search path
> will be used, unless nvcc option -compiler-bindir is specified (see File
> and Path Specifications).
> Read more at:
> http://docs.nvidia.com/cuda/cuda-compiler-driver-nvcc/index.html#ixzz3CTN6O86z
> Follow us: @GPUComputing on Twitter | NVIDIA on Facebook
> On Sep 5, 2014, at 2:47 PM, Nystrom, William David <wdn at lanl.gov> wrote:
> > I have had to comment out those lines so I could build with petsc with
> the Intel compilers
> > in a Linux environment.  That has seemed to work fine for me although my
> testing has not
> > been exhaustive.  But I have no petsc Windows experience.
> > Dave
> > Dave Nystrom
> > LANL HPC-5
> > Phone: 505-667-7913
> > Email: wdn at lanl.gov
> > Smail: Mail Stop B272
> >       Group HPC-5
> >       Los Alamos National Laboratory
> >       Los Alamos, NM 87545
> > ________________________________________
> > From: petsc-dev-bounces at mcs.anl.gov [petsc-dev-bounces at mcs.anl.gov] on
> behalf of Satish Balay [balay at mcs.anl.gov]
> > Sent: Friday, September 05, 2014 1:41 PM
> > To: Paul Mullowney
> > Cc: For users of the development version of PETSc
> > Subject: Re: [petsc-dev] PETSc with CUDA on windows with VS2013 and CUDA
> 6.5
> > On Fri, 5 Sep 2014, Paul Mullowney wrote:
> >> Hi,
> >> I've been trying to build PETSc in cygwin with Visual Studio 2013 and
> CUDA
> >> 6.5. I successfully built and ran the PETSc GPU code following the
> >> instructions for building on cygwin. However I ran in to a few problems
> >> along the way. If anyone has insight into the second problem, I would
> >> appreciate it.
> >> 1) cuda.py (lines 112, 113):
> >> if not config.setCompilers.Configure.isGNU(self.setCompilers.CC):
> >>  raise RuntimeError('Must use GNU compilers with CUDA')
> >> I had to comment these lines out to enable configuration success.
> > We might have had issues on linux with folks trying --with-cc=icc and
> > --with-cudac=nvcc [and nvcc internally using gcc causing conflit].
> > So I think this check was added at that time. Ideally it should query
> > nvcc to see what the internal compiler is - and then check if
> > '--with-cc' is compatible with it. But I don't know how to do that.
> > Perhaps the easier fix is either of:
> > if (isLinux() and not isGNU(cc)) then error
> > if (not isWindows() and not isGNU()) then error
> >> 2) This may be related to why the GNU restriction in 1) was put in
> place.
> >> Whenever PETSc has to compile a .cu, it fails. For example for a single
> >> threaded build, the first .cu file to be compiled is veccusp.cu. For a
> >> verbose build, I see:
> >> /home/Paul/projects/petsc/bin/win32fe/win32fe nvcc -c -O -arch=sm_30
> >> --compiler-options="-MT -wd4996 -O2
>  -I/home/Paul/projects/petsc/include
> >> -I/home/Paul/projects/petsc/cuda_build/include
> >> -I/cygdrive/c/CUDA_6.5/include -I/home/Paul/projects/cusp/
> >> -I/home/Paul/projects/cusp/include
> -I/cygdrive/c/CUDA_6.5/include/thrust/
> >> -I/home/Paul/projects/petsc/include/mpiuni   "
> >> /home/Paul/projects/petsc/src/vec/vec/impls/seq/seqcusp/veccusp.cu -o
> >> cuda_build/obj/src/vec/vec/impls/seq/seqcusp/veccusp.o # Compile first
> so
> >> that if there is an error, it comes from a normal compile
> >> veccusp.cu
> >> *nvcc fatal   : redefinition of argument 'optimize'*
> >> However, if I copy and paste the the compile line above and run it in
> the
> >> terminal, it succeeds. If you do this for every file .cu file in PETSc
> >> (~10-15 files). PETSc will build and work properly on GPUs in cygwin.
> >> I don't know what the problem is here. Insight from anyone with
> >> windows/cygwin/CUDA experience would be much appreciated. I've attached
> a
> >> configure.log and make.log.
> > For one - I haven't tried cuda on windows in a while. [It must be when
> > win32fe was modified to support nvcc - 3 years back]
> > And I don't unserstand the error. Is it complaining about '-O' vs '-O2'?
> > And the fact that copy/paste works is strange.
> > You can try: 'make all-legacy' and see if that works.
> > Or you can try Using --verbose option i.e 'win32fe nvcc --verbose' to
> > see exactly what win32fe is doing [from gmake and from direct
> > invocation] - and see if there are differences.
> > Perhaps there is a 'make' variable [thats read-in as env variable by
> > nvcc] thats causing nvcc to behave differently.
> > Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140905/3c6fc04d/attachment.html>
