[petsc-dev] 'master' RESET after bad merge! - 'tisaac/thplex' was based on 'next'
Jed Brown jed at jedbrown.org
Thu Sep 4 11:46:27 CDT 2014
Matthew Knepley <knepley at gmail.com> writes:
> It is important to check things that do happen. If bears do wander in
> the cockpit
This does happen, yes.
> and are not noticed for some time, then this would be important to
> automate.
The entire purpose of the inspection is to certify that various parts,
including instruments and controls in the cockpit, are functional.  The
only way to not notice the bear is to have not done the inspection, in
which case you have no business signing the certificate.  There is no
point in automating the bear check because your primary duty of
inspecting the instruments and controls is not automated and you can't
do that inspection without noticing the bear.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140904/e02f68dd/attachment.sig>
