[petsc-dev] 'master' RESET after bad merge! - 'tisaac/thplex' was based on 'next'
Jed Brown jed at jedbrown.org
Thu Sep 4 11:28:12 CDT 2014
Matthew Knepley <knepley at gmail.com> writes:
> It seems that I am talking to myself, but I will say it again. People
> miss things, especially in routine setting where it gets
> repetitive. Having automated checks and warnings is very helpful:
Reviewing commits before merging is the integrator's raison d'être.
If your job was an airplane inspector, would it be important to automate
checking whether there is a bear in the cockpit?  It's pretty dangerous
to fly the plane when there is a bear in the cockpit and if you just
sign the form without checking, some poor pilot is going to get in that
cockpit with a steak sandwich and nothing good can come of that.  But if
you actually go in the cockpit to inspect the instruments, it's going to
be hard to miss the bear.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140904/4606f182/attachment.sig>
