[petsc-dev] 'master' RESET after bad merge! - 'tisaac/thplex' was based on 'next'
Thu Sep 4 09:42:18 CDT 2014
On Thu, Sep 4, 2014 at 9:12 AM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 4 Sep 2014, Tobin Isaac wrote:
> > > My personal opinion is that maintaining a catalog of undesirable
> commits
> > > and detection/enforcement logic is not the best use of maintainer time
> > > and will not result in a more efficient system.  But if you want to
> > > spend your time on it, give it a shot and maybe others will use it too.
> > Funny you should say that.
> https://bitbucket.org/petsc/petsc/commits/a04f2a265ee1457256d59a436256ddce6a927374
> https://bitbucket.org/petsc/petsc/commits/7a9516f4bcf47790ec9d70380d83bb015f0d3e8e
> > My idea here is (a) create a dotfile in a commit that only gets merged
> > into next, and (b) add a hook to 'make info' that warns you if that
> > file is present and your branch isn't named 'next'.  This change
> > doesn't help a maintainer, who knows the workflow and can spot
> > undesirable commits better than a script, but it does reach out to
> > developers who, ehm, may not have read the wiki, and warns them as
> > soon as they start to test their changes on a branch that was based on
> > 'next'.
> the nightly builds are done in 'detached' mode - so this warning wil always
> printed for these builds.
> And when folks hardly look at git messages - I don't thinks they will
> notice
> this message burried in middle of a build. [And most of the time merge/push
> is done without a build]. So I don't think this change helps much..
I will notice.
  Matt
> Id rather folks use 'git log ..branch' before 'git merge branch'
> Satish
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140904/932d8799/attachment.html>
