[petsc-dev] [petsc-users] unreliable AMG in PETSc
Jed Brown jed at jedbrown.org
Mon Oct 27 17:09:45 CDT 2014
Matthew Knepley <knepley at gmail.com> writes:
> Definitely debuggability.
Thanks.
> It would be great if we automatically diagnose the failure of
> definiteness (I assume all these retain symmetry).
So long as a symmetric operator is input.
> Maybe we are already doing this. Then we should improve the error
> message to give the user easy options for fixing it.
We only notice it at a higher level.  The smoother could check whether
its action is SPD with respect to each vector it is applied to at the
cost of a dot product (check that x^T S x > 0).
Actually, the problem is more subtle because if one wants an SPD
multigrid cycle, they only need that the post-smoother is the transpose
of the pre-smoother.  This could also be checked, but I don't know how
to do it without significant wasted work.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141027/32a587ce/attachment.sig>
