[petsc-dev] [petsc-users] unreliable AMG in PETSc
Jed Brown jed at jedbrown.org
Mon Oct 27 16:53:37 CDT 2014
Barry Smith <bsmith at mcs.anl.gov> writes:
>    How can we insure that that the smoother is SPD? Which are known to be. In his case it was Richardson + SSOR on a bunch of processes.
The Richardson scaling cannot be too ambitious and the SSOR needs to be
an SPD operator.  I think this is true any time the forward and back
sweep is stable, which is guaranteed for an M-matrix, for example.
I'm not aware of an inexpensive way to guarantee stability/SPD smoother
for a general matrix, and even if you could choose parameters to make it
so, you might end up with such aggressive under-relaxation that the
solver configuration is not useful.
Focus on debuggability or automation?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141027/2af979c3/attachment.sig>
