[petsc-dev] EXTERNAL: Re: Do you have any suggestion in order to reduce my memory footprint?
Jed Brown jed at jedbrown.org
Wed Oct 22 18:53:01 CDT 2014
"Alletto, John M" <john.m.alletto at lmco.com> writes:
> Hi Barry,
> I am using a Star stencil, and yes a higher order finite difference scheme.
> Please help me understand how I instantiate more than the default piecewise linear interpolation between levels.
If you want higher order interpolation, you have to write it.  It won't
reduce your memory footprint, but might speed convergence (if your
method actually achieves high order and is in the asymptotic regime --
rare for production models).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20141022/d0fb1c91/attachment.sig>
